1. Priming bulb
2. Cylinder marking sensor
3. EGR valve
4. Turbocharging pressure sensor
5. Injector rail
6. Thermoplunger unit
7. Air temperature sensor
8. Disel fuel temperature sensor
9. Turbocharging pressure regulating position sensor
10. Relay/fuse box
11. Air flowmeter
12. Power computer
13. Injection computer
14. Automatic transmission computer
15. Coolant temperature sensor
16. Turbocharging pressure regulating solenoid valve
17. Vacuum canister
18. Solenoid injector
19. Damping unit control solenoid valve
20. Damper unit
21. Disel filter
I think by engine temp sensor you are thinking nr. 15 coolant temp senor.
