clio 2001 1,4 alize warning light for engine came on , had it put on a diagnostic machine came up as o2 sensor, they deleted it and it went off but came back on can i drive the car like it and how much would it be to replace. thanks
Let's be carefull out there
welcome to the forum. Don't think they are to much (around £60-70). Don't go for the cheap generic ones as they can be problematic. They are pretty easy to replace at home, 1 bolt to undo and they pull out (with a bit of effort) from the exhaust pipe, but check if you have 1 or 2 fitted and which one needs replacing
