Banned
Accelerator pedal sensor has 6 in line terminals marked 1-2-3-4-5-6 disconnect plug from sensor
at key on must have a 5v feed at both terminals
4 & 5. The 2 ground terminals are 1 & 2. Terminals
3 & 6 are signal return wires to ecu pin no's 1c1 &
1f1. At key on acc pedal fully depressed at ecu
pin no 1c1 volts should read approx4.3-4.7. Also at
ecu pin no 1f1 pedal fully depressed 2v -2.4. You may have to check wiring from acc pedal sensor plug
to ecu plug Hth Regards Mickeybo
