:( Hi all, This is my first thread,
I have recently bought a 52 megane II and have nothing but problems with it!!
First Problem being water leaking into footwell storage areas driver side.:(
2nd problem water leaking from behind the dash particularly when climate is on cool with fan on high.:(
3rd problem driving today and the esp & asr faulty warning came on ultimately reducing engine power with juddering.:(
so as you can see my introduction into megane ownership has been far from happy, any reasons for issues and resolutions are most welcome,
thanks & Best Regards, Dave.:eek:
Lop & Juddering.
If your car has a 16V lump in it then the usual suspect for juddering and LOP is the good old pencil coil units.:crazy:
I have quite a few stocked in my RSS van.
What engine have you got in the meagane? My petrol 2.0 IDE had the same issues with ESP and ASR fault. I've recently replaced the fuel pressure sensor/ regulator on the fuel rail and the problem appears to be fixed at the moment. The part isnt chaep (about 170 pounds) but its a simple DIY job to fit.
