Hi all, my first visit here, since my local dealer cannot get my 1988 espace to drive straight. It pulls to the right. It started after new front bearings and bushings were renewed. Dealer have made a 4 wheel alignment adjustment and says he needs to adjust camber - but my Hayes book notes that camber cannot be adjusted! Also two new front wheels are mounted.
Any suggestions will be appreciated greatly.
Thanks in advance.
Regards from Per / Denmark
Scenic mk1ph2, RX4, ID35s11
hi
take it to a specialist that has a laser ramp and knows what they are doing.
if camber is off there may be another fault somewhere.
most jag dealerships with full servicing on site should have one, as appossed to cheap clip on 4 wheel laser checks that most small garages will have.
Thanks for reply, but need to know if it is or is not possible to adjust camber on a phase 1 espace. If no, how to proceed. I´m stuck in the outcast of Denmark and have to use the garages here. This car was never common in DK and therefore they might need a few tricks and good advice.
So how to adjust camber on phase 1 espace??
Thx / Per
