hi i have just got a 1999 espace with 2.0 16v engine the compression is only 4 bar on all cylinders.after looking at timing belt i noticed dephaser had alot of movement. is this normal ? i would also like to no how to set timing i can see how to lock the cams but not how to lock the crank at tdc. any help would be appreciated. thanks lee
