1 - 1 of 1 Posts
Just fitted reconditioned turbo to Espace 2.2 dci 2004.
The old tubo was noisy apart from that she ran fine
Changed intercooler,oil feed pipe,oil and filter.
Took it for a spin engine check light came on put scanner on and it comes up with low turbo boost.
Have double checked that all pipes are secure.
There was a difference between the new turbo and the old in that there were 4 bolts for the cat instead of 3 for the old one.
I had sent the old one back so couldn't compare it to new one.
Does anybody know if this is a different output turbo?
1 - 1 of 1 Posts
