Just bought a Grand Espace (2003 model) & have now discovered two general faults:-
1). Water dripping from underside (located below the driver's seat). Is this normal? what is it?
2). 'Automatic Headlight Fault' warning on electronic dshboard display.
Ta
Hi divettri,
Your 2 problems...
1/ I think youll find this is condensate from the airconditioning system ... drips all the time as you actually have to turn the A/C off if you dont want it otherwise the Auto setting switches itself on and off to maintain the air quality and temp in side the car ..... on very hot days this can become a large puddle and I've actually seen a lump of ice under my car.
2/ Think this is a dealer job ... diags will cost you approx £75/hr if your out of warranty ... have you tried resetting the auto light function? ... should tell you in the hand book, I cant remember how many turns it is before you get the confirmation beep.
Hope it helps :)
