hi, posted a while ago about my espace diesel chugging and losing power, done as much investigative work as can be bothered to do in the cold and was wondering if there is a pressure relief valve in the injector pump that may be sticking, and if so where it is, can anyone shed some light, cheers, Martin
Discussion Starter #2
forgot to mention it only does it when its hot, runs fine when cold, starts doing it around 60mph, then when i lift off the accelerator and let it run with no throttle, it clears, then will go up to around 85 and then do the same again
