Can anyone help, I have lost reverse and 5th gears on my car, it was working perfectly okay until I almost got home. There is nothing wrong with the cables and I can get 5th and reverse manually at the gearbox end. has anyone any idea what the problem is
If you can select the gears from the box end ok then it is the cables or the selector box is worn take the bottom off it and check
