hi, was wondering what sort of speed through gears on espace 2.2td 1998 only mine seems very slow and the slightest of inclines engine slows right down even with foot to floor 1st gear no more than 20 mph after that very slowthen the minute on a flat bit of road speeds up slightly .i think turbo might need looking at any ideas or help appreciated :steam: thanks
Could be a turbo intake pipe or something simple like that... does it smoke loads or feel 'choked'??
thanks for reply does not smoke feels choked but every now and then it feels fine ,will look at intake pipi thanks again
What age and engine type is your Espace?
Is it a dCi or earlier 2.2dTil?
If it's a dCi there are plenty of things that need to be checked.:)
hi,2.2tdi had look at pipes and intakes all seemed fine except cold air feed on right hand side seems to be missing pipe from infeed to the flared pipe by outer edge of battery plate
