Hi - The water pump has gone and being a novice mechanic I have no idea where to start - can anybody advise if it is easy to replace this?
Hello & Welcome to the Forums Hyder.
I'm sure a Member will advise on your post shortly, Have a search through the Forums under water pump it should throw up some posts of interest to you as a number of Members changed water pumps.
Ottoman
The 1st place to start is to remove the engine.. Cos you will not be able to replace it any other way..
Tourerman
Glad to see you back WEBCODE, long may you stay, hope your still enjoying Spain.
Hello davesss, yep Spain is good and right now getting Hotter & Hotter..
