my 2001 espace 2.0 16v has begun cutting out whilst idling
any ideas anyone? thanks for your help peanuts!
it turned out to be a lambda sensor that needed resetting
my mechanic friend stuck it on a laptop today and did the business
thanks again
cionnait
dirty fuel filter blocked injector dirty air filter check all your vacuum pipes etc check all your conections to your injectors i had a similar problem turned out to be a vacuum pipe form the inlet manifold to the ecu had a pin hole that was uncovered at tick over !
