As of yesterday my 02 Espace LED dash goes out (not dim) when the exterior lights are switched on, but functions normally otherwise. Does anyone have any ideas as to the possible cause please?
Chris
I know you said 'not dim' but if the dimmer is in the 'low' position, the dash lights seem to go out when the headlights are turned on. Just make sure the dimmer is on fully bright and check again. Failing that, I'm not sure
