need a little hep with an intermittent lighting fault on my espace wherin they somw times wont switch on have traced this to one of the connectors on the fuse board which is melted and damaged causing poor contact .
what i need to know (anyone with diaolagys maybe ) where the conector runs to is it a great big long wiring run or does it go to another conector block under the dash if anyone can help (part nos owt like that would be a big help) the connector is the middle of the left hand row of connector blocks (the brown one ) in the fuse box thanks in advance for any help mot due in a week so need this asap
