1 - 1 of 1 Posts
OK folks today I went to take my 2001 grande espace for an mot and my brake Master cylinder decided to stop working there was resistance and if you pump the pedal I get brakes but if you keep applying pressure the pedal slowly drops to the floor.
  1. So I have new seals ordered and kit for bleeding the brakes from the spare tyre to make life easier to do by my self.
So here is my question my car has abs I know the whole system will need bleeding will I have any problems from my abs or will the abs bleed with it many thanks folks if you can help
1 - 1 of 1 Posts
