Hi help
The above espace is giving error codes gave me cheek ignition
Then emission then gave about 6 mour codes I e battery stater air con ect and then lost power left the car outside for 4 days came back and all find this was 4 months back did agen 3 days later took to workshop ans reset codes 54 pounds light .
As say been find now for last 8 mouths then yesterday started fine and now did same start fine but say cheek ingestion and emissions too
Weard 1 can you help
As is a pain as you can guess
Thanks andy
Hi, get it plugged in again, its no good just getting codes reset, the idea is to get them read, and then work out whats causing them, not just turning them off....
Well plug in and seems a a and workshop say e g r valve so do I clean of or get new seems new is from 150 up
Code up is Po488
So time for new 1 in looking original
Clean it, and all pipe work going to and from it..
If it does not work, then buy a new one, you still would need to clean the pipework either way.
