Espace MkiV - heater blower problem
804 views 2 replies 2 participants last post by  mh
#1 ·
Hi there!
Hope everyone is keeping safe in these unusual times.
The heater blower in our Espace will run for a couple of seconds and then stop. It might run again 10 minutes later, only for a few seconds, or it might not!
Would anyone be able to advise if this is a blower issue or a controller issue?
Many thanks!
Matthew
#2 ·
I don't know about the layout but in ours the motor is mounted vertically and susceptible to water damage through blocked shuttle drains. The motor brush braids were corroded and made intermittent contact. Replacement was the only permanent solution.
#3 ·
I’m finally getting round to getting the car on the ramps and having a look at this.
Need to decide if I go for a replacement blower or resistor....
I’m favouring the motor, as I can’t see a resistor giving such sporadic results....
Anyone have any thoughts?
