Hello all, newcomer to Espaces and this forum, hoping someone can give me some info, i've just bought a 1995 Espace 2.1 TD and the only thing i can say may be faulty with it is the rev counter flits about, ie its not steady, the engine is fine and consistent, has anyone experienced this or know how to fix it, or is it a diesel thing as its my first diesel too.
sounds like it could be a dirty or loose conection as its a diesel this is usualy on the alternator (no coil for signal )so check all the conections on the alt and give em a good clean & secure ok
cheers Peanuts you were spot on, connector on the alternator was loose and corroded so a quick clean up and a squeeze and all working fine now.thanks!!
glad to be of help least it didnt cost you and thanks for letting every one know all ads to the knowledge on here !
