:mad:
have put this in the v 6 side of the froum but hope you outhers in the outher world may help too
dads txai here
Hi all can you lot help I have a probe starting my v 6 3 litre
Escape it did start on the key with no probs but to day it wont go at all I have to use the throttle to start it and when I take my foot of the throttle it will stop last time it did this was raining a lot to ,but I have run it to get rid of the damp then spray the thing with damp seal but still wont go with out my foot on it I had an I dear and reset the outer ceasing to the throttle and it will start on the key now , but runs lumpy as you like !!!
The fuel pump sounds as if it finding it hard to get fuel but got lots in tank and others on the forum say it the t d c sincere that is 50 pound with v a t then plus fitting it go’s on so over to you
Also I got it going drove it for 12 miles and got a smell under the the car and when I look at the escorts pipe and it glowing say red hot 1 garage said it could be router cap or arm plug lads
Or even worse the head gasket so over to you HELP
Yours Andy
I had the same problem mate.
you need to take the distributor cap off, held by i think it was three screws.Very hard work your hands will get shredded on the radiator.I done this to double check my feelings that distributor cap was the culprit only to find that it was to blame but a replacement was 24hrs away.I gave the old cap a good clean using wire brush and steel wool on the metal contacts to get rid of the crappy build up on them.
The cap has been doin fine for the last 2yrs since. And in honesty i would have replaced it if one was readily available cos the metal contacts looked quite warn.SHI* it will probably breakdown tommorow.
Hi dads taxi, I agree with umed, definitely worth cleaning the contacts inside the distributor cap. ***** of a job but costs nothing except blood, skin and a bad back. Chip all the crap off the contacts and give the whole cap a good clean inside and out with petrol. Mine needs doing every two or three years otherwise it gets to be impossible to start when cold/wet. I wouldn't bother to replace it though, just clean it every few years. Definitely the first thing I'd try if it hasn't been done for a while.
