Hi! I am looking for the electric thermostat on my 1994 Espace V6. I need to find out where the unit is which switches on the two front fans. Are they controlled by the ECU? Im not looking for the temp sender I know where that is. There are four wires connecting to the fans, one of which is always +12v, one is earth, and the remaining two are unknown. Basically the fans do not come on when the engine gets hot. All relays/fuses checked. I have wired up a manual switch but this is only a temporary solution. I would very much like them to come on auto as the wife will blow the head gaskets otherwise!!
Thanks in advance for any help!!
Hi Skiline - sorry I don't know much about your type of car. Does it have air-con. Are there any switches or sensors fitted to the radiator or hoses going to and from it.:)
