Espace III 2000 16v 2.0i
Hi everyone, I am at a loss here and hope someone has the answer. I am trying to remove the dash trim in front of the steering column. That is the cloth trim which is level with and either side of the top opening section of the dash glovebox. I can see no obvious way of any fixing whatsoever!
Thanks for any help.
hello
after changing the bottom joint on the steering column:crazy:
you basically need to remove the airbag ( be carful ) theres three screws on the front steering column 1 inside the radio control about five screws underneath the steering column shroud remove the top part and there will be two screws attached to the piece with cloth on there is also screws under the panel were the headlight control are its a complete pain and there are torx screws t20 i think hope this help :d
