Hi all, im new to this so please bear with me,
i have a 2007 Renault traffic with a light on the dash, the book says its an ''exhaust gas monitoring light''.
Does anyone know how to turn this off, or can damage be done to the engine if i keep driving.
cheers
The monitoring light will have illuminated because the ECU has detected an engine fault. You may be able to erase the fault code from ythe ECU but if the engine fault isn't remedied the warning light will only come back again.
If you posted up the exact engine type you may get more replies.:)
hi, i have renault magane fidgi 1.6 16v 2002 model. For the past week the warning light for monitoring exhaust gas has been flashing. Why is this? is it something to do with coil?
