I have taken a gamble on a ebay item, its a stainless steel cat back exhaust system off a 5 door megane coupe around 1999 plate.
Question is will this fit on a 1998 renault megane coupe with or without mods...only cost £40 so worth a gamble:confused:
It will definately be different and need modifying to fit,it's not beyond the realms of possiblity to get it to fit though.:)
Ideally you will need to get the car on a ramp and see exactly what needs to be changed.The Coupe exhaust will be shorter,either the centre or rear sections will need to be cut and shut.The flange at the front of it might be different too,but from memory the centre pipe mounts in the same way,I'm not sure about the rear part though.
