hi all, iam new to this wonderfull site, i have a 56 plate 2.5 dci master will an after market fault code reader work on this model, thanks for reading.
R
Hello and welcome to the Renault Forums :)
Yes as long as it's EOBD / OBDII compliant though apparently they don't always access all the error codes and only access the ECU not airbag or ABS systems for that you will need a proper scanner like a Renault CAN Clip though a Chinese clone will cost around £200.
