Renault fault codes start with DF. What fault reader is being used? What are the symptoms?Hi, just wondered, did you ever solve this problem, as our diagnostics are coming up with the same code (same model car) & we can't find what the code is for
Just fixed a similar issue on my IDE ...Hi, the fault reader is a snap on ethos. We've only just got the car, & before that, it had been sitting up for about 18 months - 2 yrs. When we first got it, there was no problem, then it went into 'limp mode'. A friend of ours diagnosed it, & the above code is the one it came up with! Not really much to go on, I know. The only other things we did, were replace all 4 tyres, front spring, & both front anti roll bar drop links. Any ideas would be greatly appreciated!!!
