Does anyone have a definative list of what puts the Warning light 'Fault in Fuel Injection' light on. Or are the possibilities too long and distinguished to be listed.
There is a loss of power assosiated with the warning light which I assume is the Limp Home Mode.
It only comes on when the engine is fully warm, and generally happens when accelerating fairly hard.
I have cleaned up the EGR Valve - But am still Desperatly trying to avoid the dealer!
Any help gratefully recieved.
Cheers Taffny:crazy:
hi there, do you get a surging sensation if you are holdig speed? does it smoke? could be intercooler airflow meter egr valve the list goes on!
good luck
bigshow
Hi bigshow,
No it doesn't surge at speed, but I do get a little bit of smoke!
I gather there are a load of possible causes, I've done EGR Valve but might have a look at the air flow meter.
Cheers, Taffny.
