Last Friday my daughter was driving along and the fuel low warning light came on, I thiught she was just low on fuel and proceeded to put in £20 of petrol, I took it down the road and after a short time the gauge showed between half and three quarters full. I thought all was ok, but the following day the gauge was showing empty again, so thought I would have a closer look. Having made a tool to unscrew the ring holding the pump/ sender into the fuel tank I checked the resistance as i moved the arm up and down and seemed to be ok. After re inserting pump and sender unit I then decided to have a look at the gauge cluster and, having removed the gauge cluster there was nithing really that I could check, I so had to reassemble without solving the problem. Does anybody know if there is a separate fuel gauge control unit on these models or has anybody else experienced this problem and been able to fix it.
Rowan
as above sum1 answer plz!!!
I have the same problem! have been using trip miles to guess when to fill up car!! sum1 answer plz!!!
To check if the tank sensder unit working correctly you need to check the voltage at the guage and not the sender - some models also have a voltage regulator which can go faulty (intermittently). In my experience the most common cause of duff fuel readouts is down to a poor earth somewhere.:)
faulty fule gauge an megane
I have sorted my fault, first of all I purchased a second hand gauge cluster but that made no difference, the fault was still there so I proceeded to check the wiring and traced it under the rear seat to the passengers side where it runs under the trim to the front passanger footwell where there is a big multiplug, when I disconnected and reconnected this plug, the fault was cured, obviously a bad connection in the multiplug, anyway it has been fine since I did this.
Hope this helps
Hi Rowang - glad to hear you got your problem sorted many thanks for your update - all goes to help run a successful forum:)
We have the same problem with our megane 1.6rt, one min it shows empty, i put £10 in and it showed as half full then 22 miles later it showed empty again which is impossible. Have checked the fuel lines and they havent been tempered with, i will follow your advice and check the wiring this week and see if that cures it. Steve
