hi, i have a x reg scenic which i am trying to fit a cd head unit and multi disc changer out of a rover car. i have got it working without cutting any wires,the plug to the dash display is not connected and the plug to the stalk control is also not connected, the speedo is no longer working and the auto central locking has stopped. is there a way round this. many thanx
Don't wish to sound unhelpful, but assuming everything was working prior to this 'installation' then I would think it indicates that you should perhaps revert to using a Renault Cd player & changer. That should solve any problems.
The bits you are unable to connect up, are for the display and the steering remote.
You may be able to obtain adaptor's to use these features but by the time you add up the costs you are probably better off using originals.
Try: Car Stereo Fitting Kits - Nexxia
secure.direct-websites.com/caraudiodirect/best_sellers.php
www.autoleads.co.uk [Home Page]
incarexpress.co.uk/pioneer_car_audio.php
Good luck
