Hello, my son has a v reg year 2000 clio he has just bought some second hand spotlights/foglights, can anyone tell me the best wy to wire them up without buying the special loom from renault, can they just be wired to the side lights?
Hi Gray - Are these the proper Renault fog lamps - if so have a look behind the existing blanks for a cables or connectors. Depending on the model it may be possible to connect to a renault fitted switch. Under no circumstances should you run them via another circuit as the cabling is probably not capable of carrying the current and may result in a fire. Additionally fog lamps should be wired so they are only available when the dipped headlights are activated
Do a search of the forum I think there are a few posts on the subject
