took my car to an audio place 2 get my sony cd player fitted into my megane coupe to work with the controls. i had previously bought all the leads to connect it from halfords. once he had connected it the guy said that the remote on the steering worked but was the wrong way round but he said he would find out how to change the sync of it.
5mins aftr i left the place i found that i couldnt change the volume, cdtrack/channel or take the cd out unless i restarted the set, using both the buttons on the cd player and the steering wheel remote! took it back to the place and they said it wasnt the wiring but the cd player
went and bought another sony cd player then when on to discover that the orignal 'broken' sony worked if you disconnected the plug for the steering wheel control!!
long story but was wondering if anybody would have any idea as to whether its the way they connected the wiring or whether there is the possibility of there being a fault with the cars wiring?any help would b much appriciated :d
If the remote controls worked on your old set,then you have to suspect that either the wiring adapter is faulty\wrong or the wiring was connected up incorrectly.
Yep, obviously not very good at fitting audio these 'audio fitters':rolleyes:
Sounds to me like it was wired up wrong aswell.
