looking for friction plates for renault espace 2.2 diesel 2005
Viv Number VF1JKOHCB33255036
thanks in advance
Find the vehicles 4 digit type code from the oval sticker ( on the B pillar, drivers side, top left hand, 4 digit code) then go here:
Pick the correct car and then pick the correct engine code, then go down to Item 20 on the left hand side and click it, it will give you all the part numbers for you clutch, when you have that you can then search for that part number
