Hi everyone,
I have renault scenic 2, 05 plate and have moved to Germany!
I have to register my car here as i will be staying for a while.
So to do this i need to change headlamps and rear foglight to the LHD sides.
Headlamps are easy for me as no rewiring needed.
Rear fog light
The way i figure it is that i just need to find the fog light cable and extend it to reach the other side. However looking at the wiring connectors on the right compared to left they are different in the that the right has 6 connectors and the left only five(although has space for 6, i'm guessing the extra is for the fog light). Also the left tail light cluster has one red section that doesn't get used(i'm figuring i can use this as the foglight) So here is what i intend to do,
cut all cables to the right connector and swap the connector with the left one, and extend the foglight cable to the left.
However what would be really handy is an idea of which cables are for what in those connectors so i can reconnect them properly. Can anyone enlighten me? Or even let me know if they spot a flaw with my plan.
thanks in advance
Craig
Rear fog light
thanks in advance
Craig
