To give your car that perfect visual and performance touch, the engineers at Direnza have created a complete line of wheel spacers. These are designed to give your vehicle a wider, more stable stance quickly and easily. With the correct Direnza spacers installed, your car will take on a more aggressive look with wheels and tyres filling the wheel arch exactly the way they should.
Fine-tuning your track width doesn't just enhance your car's look, it also gives you improved handling, performance and optimised roll capabilities. Direnza spacers are available in a range of sizes, letting you position your tyres exactly where they will look and perform their best. All Direnza spacer kits come complete with all necessary mounting hardware.
The Direnza wheel spacer is one of the easiest and most cost effective bolt-on performance handling enhancements for your vehicle.
Manufactured from high strength lightweight 6061-T6 aircraft aluminium alloy, forged hard anodized for durability and corrosion protection.
Precision engineered hub-centric and model specific for a perfect fit and wheel balance.
Limited life range tested for wheel bolts/studs (1 million times) in accordance to ISO3800.
Strength tested for applications (bolt/stud/nut) in accordance to IS0898-6, SAEJ429, SAEJ995.
Anti-rust tested (NSS 72 hours) for applications (bolt/stud/nut) in accordance to IS09227.
Improves wheel and tyre spacing within the wheel arch.
Better handling.
Increased safety by widening the vehicle track width.
Fix brake caliper to wheel clearance issues - particularly when fitting big brake kits.
Adds inner arch and suspension clearance.
100% genuine Direnza product.
Fitting instructions included.
Brand new in the box.
Fits:
Nissan 200SX S14 (94 - 98)
Nissan 300ZX Z31, Z32 (89 - 92)
Nissan 350Z (02 - 09)
Nissan 350Z (09 - Onwards)
Nissan Almera Tino V10 (00 - 06)
Nissan Altima (02 - Onwards)
Nissan Cefiro (95 - 04)
Nissan e-NV200 (14 - Onwards)
Nissan Fuga (04 - 09)
Nissan Fuga (09 - Onwards)
Nissan GT-R (08 - Onwards)
Nissan Juke (10 - Onwards)
Nissan Leaf (10 - Onwards)
Nissan Maxima (04 - Onwards)
Nissan Maxima QX (95 - 04)
Nissan Murano Z50 (04 - 08)
Nissan Murano Z51 (08 - Onwards)
Nissan Primera P12 (02 - 06)
Nissan Pulsar (14 - Onwards)
Nissan Qashqai J10 (07 - Onwards)
Nissan Qashqai Plus 2 J10 (08 - Onwards)
Nissan Quest (04 - Onwards)
Nissan Roque (07 - Onwards)
Nissan Serena (93 - 00)
Nissan Skyline R32 (89 - 93)
Nissan Skyline R33 (93 - 98)
Nissan Skyline R34 (98 - 02)
Nissan Teana (06 - 08)
Nissan Teana (08 - Onwards)
Nissan X-Trail T30 (01 - 07)
Nissan X-Trail T31 (07 - 14)
Nissan X-Trail T32 (14 - Onwards)
Renault Koleos (08 - Onwards)
Before purchasing any wheel spacers please measure the gap between the outer edge of the tyre and the wheel arch. Take 5mm from this figure to help give the maximum thickness wheel spacer suitable for your vehicle. It is good practice to work to 5cm less than this figure to allow for movement in the vehicle suspension. When measuring your wheel gap always measure both the driver and passenger sides on the same axle as measurments may differ slightly and you should always work off the smaller of the two figures. This is especially important as spacers which have been fitted and / or tested cannot be returned.
Below you will find a brief glossary of terms you may encounter when checking the suitability of wheel spacers for your vehicle.
Price: £66.66
Price (inc. VAT): £79.99
Please see the website for more photos and details...
Our new performance tuning parts are guaranteed and can be easily purchased online with accurate stock levels displayed. Just select your manufacturer below to see the range of stock available. Our parts are specially designed for motorsport, racing, drifting, hill climbing, drag racing and general tuning. Whether you need a new exhaust, brake discs, engine filters or suspension parts, we have it all in stock.
Buy Online
We have a full range of new tuning car spares and parts online stocked and shipped in the UK. If you cannot find the part that you need, please get in touch with our specialist team and we will be able to help you. We have access to a wide range of suppliers and can help you find the replacement tuning and performance parts that you need.
More great items brought to you by:
THE MOFF SHOP / TMS MOTORSPORT
FS: DIRENZA LOWERING SPRINGS SUSPENSION 30MM RENAULT CAPTUR 1.2 Tce 120/1.5dCi 90/1.5dCi 110
Fitting a set of Direnza lowering springs is an easy & inexpensive way to dial in your car's stance & improve its handling one...
FS: Renault Clio Stainless Steel Catback Exhaust System
Manufactured from high quality T304 grade stainless steel.
Mandrel bent and fully TIG welded for strength and durability.
CNC machined flanges...
FS: DIRENZA LOWERING SPRINGS SUSPENSION 30MM RENAULT MÉGANE HATCHBACK 1.2TCE/1.5dCi
Fitting a set of Direnza lowering springs is an easy & inexpensive way to dial in your car's stance & improve its handling one go...
FS: DIRENZA LOWERING SPRINGS SUSPENSION 30MM RENAULT MÉGANE GRAND... - TMS Motorsport
FS: DIRENZA LOWERING SPRINGS SUSPENSION 30MM RENAULT MÉGANE GRAND TOUR 1.2TCE/1.5dCi
Fitting a set of Direnza lowering springs is an...
