hi im new at this so not quite sure how to go about it. i own a grand scenic megan 1500 dci. ive just changed the fuel filter and cant bleed the system to get car going again. can anyone please help
Look for a rubber bulb usually on the fuel line just before the fuel filter pump this till the filter is full and you don't see much air in the lines then try to start it keep it running at a fast tick over for a min or two and it should be ok.
