hi usually the fuel filter is close to the fuel tank underneeth the car, normally a canister with a pipe in and pipe out. have a look underneeth you should see it, if its not hidden by a plastic cover. tj
Fuel filter is located in front/mid of fuel tank, it is a metal cannister with an inlet and out let pipe, be very cautious when removing pipes there will be back pressure of fuel, ideal to have container ready to catch fuel. Hope this helps.
