1 - 20 of 24 Posts
:rolleyes: i have a Renault Clio 1.2, 2001. i have a new problem, the oil light keeps coming on, filled the car with oil and had the car serviced still the light keeps coming on when the car is ticking over. once you move off the light goes off, any advice is much appreciated.
RIP 31-12-2008
Hi there Gail and welcome to Renault Forums, hopefully someone will give advice soon, :)
Regards Leroy
Tourerman
I think from your previous posts your immobiliser light might not be on. :)
As Hondo says it is probably the Top Dead Centre sensor, this is a cheap and easy fit, 30 minutes labour charge and approx £15.00 for the part. Most times just having the sensor cleaned solves the problem.
A fault with the TDC does not show up on a diagnostic check.
Banned
It on the flywheel end of the engine, above where the engine mates to the gearbox.
It looks like the attached file.
Discussion Starter #16
found sensor, can i remove and clean without problem or does it need to go into a garage?
1 - 20 of 24 Posts
