hi to all
my espace 94L reg 2.1 td manual gears are playing up
when i first start it after a wile its not to bad it had new clutch/cable last year some say change box oil some say not
could it be clutchcable needs adjusting if so can it be done by me or do i take it to renault dealer or if change box oil were are the bolts to un do reverse as to be the worst
it crunches for a bit then gos in normal after a wile same as first gear but like i said after about 20mins lovely and smooth im hoping its not a gearbox problem as with engine of i can find all gears with no problem at all so hope some one give some i dear as to what to do
thanks gary;)
Hi Gaz - have a search through the forum - you find ithers with similar problems - seems to do with the gear change mechanism:)
