Hi -
I have a problem with an 03 espace 2l petrol. I can change gears when engine is off but can't get the car to go into gear with engine on. I've also tried putting the car into gear beforehand, putting in the key card, starting the engine, the engine starts but the gear pops out into neutral after a squealing sort of sound - any ideas?
Cathal
collapsed clutch release baring ??? could your clutch need adjusting has this got progresivly worse or just happend overnight ? a clutch fault has got to be the chief suspect
This happened overnight - but its back working again. It appears as if the clutch pedal was releasing only half way up, so the pedal was only half engaged. somehow, it got released fully again and alls fine again - worrying though - any ideas
