Discussion Starter · #1 · (Edited)
Okay, I'm stumped. What's the gearbox oil change procedure for the 6 speed gearbox as fitted to the Clio Mk3 1.5 DCi 106? I was expecting to drain the oil from the bottom plug and then refill from the winged filler/level plug in the front of the gearbox - but the 6 speed doesn't have a winged filler/level plug.
I've seen the thread on gearbox oil changes and read through it. There is mention of a different process for 6 speed boxes but this isn't described for the Clio. Help appreciated :)
Discussion Starter · #2 ·
After some frantic googling, apparently it's a TL4 transmission. The oil capacity is 2 litres and the filler is at the rear of the box near the left hand drive shaft. No wonder I couldn't find it! I'm going out to the garage for another try now.
