hi
hope someone can help my traffic 2.1 deisel camper is leaking water from the drivers side drive shaft i have replaced the pipe that goes into gearbox from bottom hose and the one from top hose looks ok, but when i fill up with water it comes out from driveshaft:
We've had this mentioned on the forum before,but as yet we have no fix for it.Another member said that they had a coolant leak from the gearbox area and I basically said that it can't be coming from the gearbox,but they posted a picture of the system and the coolant does seem to go round the gearbox in some way!:eek:
I'm not sure what can be wrong,but hopefully another member can help.
watercooled gearbox
hi thanks for the reply
today i found the cause of the problem
it would appear that there is a water jacket ar4ound the diff/gearbox and they have a habit of cracking mutch like an engine cracks when frozen, it looks like the previous owner left it with no antifreeze, my local garage quated £473 for fitting new box and new clutch.
anyone know if that sounds about right:
