Hi , I have an 2011 grand scenic . Which runs fine when it’s cold . But after some
Miles the I think the first or the second gears latches on until 3500-4000 rpm for it to change over and then after again. Runs fine until you come to a stop. Again it takes excess rpm for the car to start changing first gears. Obviously after words gives a message that Auto gearbox overhearing .:( . Please help
Full auto or some other fancy box?
If auto I would confirm ATF level ok, and then get a Clip or some Renault speaking scanner and inspect the gearbox parameters to see whether the lockup function on the torque converter is actually working - if its not then a guaranteed source of overheating ................
