:confused: hi all
this is my first time at this so please be patient with me, i drive a v reg scenic and i have quite a serious problem with my car it has a serious lack of power it starts fine and ticks over fine but when i pull off it has no pulling power at all when i deed to pull out at juntions ect i have to allow more than the average time, i have taken it to a renault dealer, 2 specialist deisel companies, a local garage and an independant deisel mechanic all have agreed that there is a problem but non can find what it is, the independant found that a warm vacum hose was blocked which he cleaned this seemed to ease the fault for a short period then it just went back to being the same, i'm being told that because there is no fault showing on any diagnostic check that the fault is almost certainly mechanical, is there anyone who can help as this has been going on for months now and has become a real pain
Yours hopefully
hi chris
thanks for the suggestion, i don't suppose you know how i can identify the maf sensor i'm fairly confident around engines but have not done any work on this one at all and would like to check your idea out before i have to part with cash for someone else to do it i do have a manual but cannot find the info i need
thanks again gemnick
thanks again
