Yes but yours is an easy fix..
BMW, Crank sensor for every engine fault, even when a hose has split,.
Air bag fuse goes on a beemer, crank sensor fault, rear light cluster with LED's fail, crank sensor fault.
Bulb goes on the cluster, yep crank sensor fault ..
Or got put a new battery on, tell the car a new battery, bulb gone tell the car a new bulb...
So are Renaults really that bad.
