My 2002 1.2 16v clio is acting a bit odd at the moment, it idles a bit funny with a puff every few seconds and cuts out if revs are not kept above 1000rpm, and there is a light on the dashboard which looks like the glow plug light in a diesel but this car is petrol.
Im not sure what the problem is and i don't have a book with the car, there is also a light saying 'SERV' and one for the airbag staying on.
What would solve these problems, i would consider buying a fault code reader but don't know what one is best for renault, is there a renault specific one.
Check your coils in your engine for signs of burning. The airbag/serv light will most probably be related to a loose block connection underneath usually the passenger seat.
on a clio is the coil the box at the back of the engine between the engine and the bulkhead.
No that sounds like your auxiliary fusebox. The coils are actually plugged into your engine. There's 4 of them. You may need to remove a screw for each one.
