Thought I had a flat battery a couple of weeks ago. Used sons car for a couple of weeks and bought a battery charger. Battery now charged and there is absolutely no sign of life from the Laguna electrics. The car is insecure, but that's not a real problem, unless the thief knows how to fix the problem.
Does anyone know if there's a simple fix, before I contact my local mechanic?
Cheers
george
Hi monty
It maybe worth checking the positive lead with a meter,not sure about the Laguna but the first fuse is a big one (100 amp i think) fitted in the positive. Never heard of it blowing but worth a try.
If it has blown there must be some serious short circuit.
Just a thought.
No Electrics
Check the polarity of the battery - using a meter - and also what the voltage output is. If a really dead battery is charged the wrong way round it's polarity can be reversed. See if you can borrow another battery and see what happens.
I've checked the battery with a meter (not really sure if I was doing it right, but the needle moved when I connected to both terminals). Think tha battery is charged and connected properly.
I cannot find a 100A fuse in the box behoind the battery, but the fuses that are there look OK.
I think I'll have to get my local mechanic on to this one. Once its fixed its up for sale.
