Hi all, anyone out there able to tell me how to remove the door-lock barrel from a yr 2000 Grand Espace please. The existing barrel inner has broken, and came out with the key! I have obtained a replacement barrel (complete), but can't see how to get the remainder of the old barrel out. I have the door panel off already, but the lock is not easy to get at!! Any help would be much appreciated. Cheers.
Now i don't have any door locks on my Mk III apart from the emergency door lock on the passenger side so iam guessing this is the lock you are talking about??
If so yes your right...things are tight in there:crazy: and if memory serves me well there is clip that is holding the key barrel in place from inside the door panel and that needs to be removed for the barrel to be pull out to be replaced,
Hope that helps Donald
