1 - 10 of 10 Posts
I'm thinking of getting one, is there any things i should be looking for when I go and see one
if you are talking second hand the only advise i can give is.watch out for v6 petrol.i am not saying they are bad cars but most are taxi's and if they look far cheeper than the diesel running costs aint it .if you do go down the route of v6 petrol make shure it has documented timming belt change on the 24 valve model motor has to come out to change belt £1000 + thats the only thing i have against the 24 v v6 diesels more m p g
watch out for clutch problems, heater matrix leaks near your feet, tracking, heater controls, egr valve, these are just a few problems that are associated with the espace.:crazy:
thx for your advice guys, I am looking at a 2.2 deisel so the V6 thing aint a prob, I will look out for the other bits
I've got a '99 2.0 petrol grande.
A pretty good bus really, just watch for the irritating airbag warnings.
Though someone has posted how to fix this issue.
Apart from that it starts and goes, not bad.
Hello and Welcome to the Forums.
I would do all the usual checks.
Make sure everything works as what could seem a simple repair can work out very expensive on the Espace, tyres can be pricey. If buying from a dealer make sure you get a very comprehensive warranty, Check all service documents very carefully, Change oil and filters more often than recommended and use a good quality oil, Check out the service costs at your main dealer , Some very good Renault specialists around who are considerably cheaper Buy with care and you should get many years of good service from your Espace .
Lots of info here on the Forums if you do a search.
Any doubts I'm sure our Espace Members would only be to happy to help.
Ottoman
diesel grand espace
Feel free to look up my posts. They cover the good the bad and the ugly. I have a fibreglass '98 RXE and it is the business. Can do 40+mpg on the open road (at 56mph average) and never less than 33. However, if you want to use that turbocharger you can get 15mpg at 105mph.
Carries a full double bass and four people! Don't break a cambelt (£1000) and don't believe the last owner changed it unless you see AND VERIFY the receipt. The '98 model is the best made Grand Espace and the J8S engine is the best engine.
Hi, i've got a 2003 2.2 dci grand espace. Great car for distance on the motorway, parts from dealers expensive (shop on the net). Only prob i had was the intercooler blowing at 47, 000mls, had it replaced by a non renault garage Part £235 + £200 labour, renault refunded cost of part after a strong letter to them but would not pay the labour because it was done by a non renault dealer. But since then it's been fine. Oh and i can't change the speedo over from mph to kmh (as it says on in the book, or on this site). still trying though if anyone has any other suggestions.
1 - 10 of 10 Posts
