1 - 1 of 1 Posts
Hopefully someone can help as everything seems to make this problem worse. After changing reat brake pads the foot pedal wasnt pumped before applying handbrake and since then had the strangest problems. Started just with a parking brake fault message and the handbrake didnt seem to come on when pulled. A strange noise seemed to come from motor each time it was applied. Was advised by a mechanic to repeat brake pad process but pumping the brakes this time. After this the parking brake fault is displayed but also not a parking brake lock message. When looking at the caliper the handbrake cabe doea appear ti be locked on but the car is not stationary and still drives. What could the problem be and how do we get the cable to unlock the brake, so bloody confused - please help TIA
1 - 1 of 1 Posts
