1 - 9 of 9 Posts
Afternoon all!
Having just got back from my first experience if a dealer service on my first Renault i'm after a little advice.
I paid for an air con service to be told that there is a problem with the pressure switch and that they were sure it was this after doing continuity testing on all the associated wiring etc.
I have read several post concerning air con on this model and wondered if anyone could offer advise on the following questions.
  1. I've been quoted £120 to replace the part but have read of folks getting them for as little as £30. I have the part number but can anyone recommend a way to get hold of one?
  2. Is there anyone who can offer advise on how to replace the switch? As i understand it i can find it under the front on the engine behind the bumper attached to a valve that enable the switch to be removed and replaced without loss of gas.
Any advice would be gratefully recieved.
Oh, excellent forum by the way!:d
Try looking for a Air Conditioning Pressure Switch Sensor RENAULT on ebay.
I suspect the biggest part of the price quoted is down to labour due to bumper removal etc.:)
Great advice, thanks for the rapid response
The dealer provided a parts number which was matched by the number given on the sellers page on ebay.
Now point number 2. The seller gives a few instuctions but they are a bit basic. Can anyone give any more details guidance?
you need to remove the bumper. 3 10mm bolts underneath. 2 torx20/7mm bolts under wheel arches. then the twisty black clips on top of bumper and a few torx screws there too. unclip bumper from top. with a lil gentle persuasion it'll all come off at once. unclip fog lights and look at bottom left of air con condensor. the switch is there. its a 14mm fitting and will not leak refrigerent. lube your new seal with a touch of engine oil.
:d:d:d:d:d:d
How good is that then? Thanks so much to both of you!
£30 for a switch from ebay and instructions that i think will take me about an hour tops to sort.
:d:d:d:d:d:d
Part delivered today, looks shiny and new, it's even printed with the part code and renault on it.....i know, i'm easily impressed.
I shall let you all know how easy it was and see if i can remember to attach some photos for reference of other members.
Excellent guide to removing the bumper of a Scenic II here including pictures!
http://www.renaultforums.co.uk/showthread.php?t=85760
Sorted, Bumper removal was simple using the above guide. As previously stated the sensor is on the left of the radiator and neede dto be unplugged, unscrewed with a spanner and the new unit put in it's place.
Interestingly, and i'm no expert but even i could see the new unit was of much better quality than the original. More alumiunium and lest plastic.
I now have nice cold air just and the weather decides to do the same!
1 - 9 of 9 Posts
